Discuss Fitting new consumer board - no part p? in the Electricians' Talk area at ElectriciansForums.net
tomodo
Hi guys my friends ask me to replace his consumer board Ive been qualified for a year or so have my nvq level 3 but no inspection and testing yet! What are the rules for doing it? Is it okay for me to install it and then get an experienced part p registered electrician I know to test and certify it? Is this also legal? And also when I do get my 2394 and 2395 how do I go about doing one off jobs without becoming part p? Cheers be grateful for replys
are you competent to do it? do you have the necxessary test gear to test and certify?
if yes to both, then just ge --- done.
the part pee police might prosecute you if yo make a balls-up and injure someone.
So lacking in experience, no test kit and no membership.
Any PL insurance?
Me thinks you should walk away or if you do it, make sure you buy your horse some more straw.
We'll it'll get tested after it's been installed so why should that be a problem? Seems a lot of money to get registered if I'm not doing it as a business. Work full time as maintenance in a factory thanks for the replys
So what are you going to do when the RCDs are tripping?
What if you have insulation faults, you won't know until you turn it on and the RCD wont stay in.
So you pull the fuse, rip the board out, and wonder why those VIR's are crumbling before your eyes.
And that's just the beginning !!
Look before you jump, that's the Grand Canyon looming before you.
Realistically you should never consider doing a consumer unit change without carrying out some basic tests , whats the cable is it PVC or the good old VIR , what about bonding to services water gas oil etc these i name a few and as beens mentioned insurance
get yourself a tester mate, no need for £500 new shiny one, second hand machine doing insulation resistance and continuity will do, every electrician should have one and know how to use it...
tomodo, leave it alone, no test gear how can you do it, never ever change a CU without testing the entire installation before you rip the old CU out, you are installing a CU wit RCDs in it, just think about that.
No test equipment so that's a no go. Just wondering what the law was?
The law is "The Electricity at Work regulations 1989". This is what you will be prosecuted under if it goes bad. A lot of people think that this law doesn't apply to Domestic Installations, they are wrong, if you are doing stuff in your own house it doesn't because it can't be enforced, but if you do it in someone else's, it does and you will get crucified.
Building Regulation Part P is also the law.
Cheers.............Howard
Sorry, and I mean know disrespect to the OP.
But reading through this thread your simply not ready to approach the task at hand.
Remember,
Being competent has never been about what you know.
Its about knowing what you don't know.
1st stage is to have the whole installation thoroughly tested as per an EICR.
Don't need to complete the whole form if factored into your price but you need to visually check the installation and record readings for your benefit.
Once you have identified any dangers or non compliant problems you can tackle the job issuing an installation cert after completion.
Part P registration is as much, if not more, for your friends benefit.
You need an established qualified sparky at your side and run through the job with him.
That's my honest opinion, and advice. :icon12:
Hi all
before part P came in what did you do on a CU change we did the same as every body else 16th edition install all circuits turn it on if RCD holds the system was fine.
Only difference now is part P & don't get me wrong I am all for it as long at it policed properly which it's not. I still know people who do cash installs who do a couple of test mainly LE Ne M ohms & earth tests & F... All else. It still goes on.
Hi all
Part P or no Part P, I wouldn't install a new CU without some pre install tests, nor miss out all the circuit testing, nor issueing an EIC.
Hi all
Absolute rubbish not every one else i can assure you , and they will be they ones who will eventually end up in court
Hi all
I can assure you that before part p was introduced the vast majority of electricians worth their salt did exactly the same as they're doing now.
Pre tests, CU change, full test, cert.
You're talking utter nonsense and if that's what you used to do then you should hang your head in shame
Hi all
I would agree with you 30 odd years ago, and I won't say why just yet (privatisation is the clue).
Take them out and stick a double pole switch in of course :biggrin:
Or even worse, I've seen the RCD installed but unresponsive, some nugget had actually cracked it in half along the seam of the casing and bodged a piece of 16mm cable to bridge the top and bottom. And TAPED it together.
crack on m8 every tom dick or harry is having a go anyway ,Part **** is a joke.
we,ve all see the thousands of prosecutions for failing to notify building control.
every year i wonder why i bother paying for this shambles
I'm interested to know what "pre-checks" you undertake (rather than a full test), prior to replacing the board - Ze, Polarity, IR each circuit, check main bonding etc?
In addition to above I like to whip the upstairs/downstairs passage landing light switches off for a quick look to see if I am likely to face a borrowed N situation, plus to see if there are CPCs present on the lighting, a quick visual as you can tell early doors if the wiring has been hacked about/bodged DIYed etc. plus a quick clamp of the tails with my earth leakage clamp meter to see if I am likely to face RCD tripping problems, oh and I don't usually IR test every circuit at this stage usually just a quick global L+N to E.
I usually spend no more than say a half hour doing this at the quoting stage, this has paid off every time and being well worth the time and effort spent, this tells me if it is going to be fairly straight forward or a complete ball ache of a job, and I can quote accordingly ;), I never "formally" record anything at this stage just a few notes for myself, and never give the client any of the results at this point either.
I learnt the hard way lol, only the once though! :)
Suitable tests to give you an indication that you don't have any pre-existing faults or a shared neutral situation between up and down stairs lighting circuits. Failure to do pre-testing can lead to a whole lot of problems on a CU change with RCD's tripping etc.
And typically just as you were thinking of or looking forward to going home too... lol!!
Reply to Fitting new consumer board - no part p? in the Electricians' Talk area at ElectriciansForums.net
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
