Hi, Is this correct? You should put the FCU into the ring main, (so extend the ring in other words) or is it still okay to take a spur from a socket in the ring to the FCU, and then feed something else? Get my meaning? I was always told to put the FCU into the ring and then spur from that. What do you guys say? Cheers.
you can spur to the |FCU as it's fused@ 13A. spur should not be of excessive length, though.
Get your Regs book out and look at Appendix 15,
FCU from ring
derry0178,
Plonker 3,
