No. The only 2 lights that worked were the main light and side lights. I can get the others working by swapping the switched live. Not an ideal test I know but proved they can all work. So I know cables are all fine at least they can finish the build. It's got to be a connection either in the junction box or the switches. Most likely junction box...... But where to start.
as eric morecombe would have said:
"i'm connecting all the right wires, but not necessarily in the right order".
Ok I will pull this junction box apart. Label it all again and try again.
I'd be inclined to ask an electrician to help you out.
OP have you charged your customer for any works you have carried out on this circuit?
Is your customer aware you dont know what you are doing?
Hold on, I thought this was an existing set up, not a build or extension!
Its a favour for a friend. To help me expand my knowledge.
Have you wired up these lighting circuits or were they already there?
If they're new circuits, you'll have to notify "The Council"! :smilielol5:
