Disconnect everything. Test all cables to see which is which, and that none are o/c.
Reconnect in junction box in correct order. Daz
No. The only 2 lights that worked were the main light and side lights. I can get the others working by swapping the switched live. Not an ideal test I know but proved they can all work. So I know cables are all fine at least they can finish the build. It's got to be a connection either in the junction box or the switches. Most likely junction box...... But where to start.
Hold on, I thought this was an existing set up, not a build or extension!
as eric morecombe would have said:
"i'm connecting all the right wires, but not necessarily in the right order".
when the lights are meant to be on, just see where the voltage to earth is not 230V before the light, or is 230V after the light (without electrocuting yourself) , where this changes is the cable with the fault.
I would expect a problem with how the lights themselves are wired for three lights to fail with that Junction box arrangement.
I'd like to know what a side light is.
I'd also like to know how you're testing for polarity on any of your jobs mate. A plumber mate of mine has done the Electrical Trainee course (against my advice) so he can install spurs (and that's all he does) and even he, a pipe monkey, knows how to do a polarity test
OP have you charged your customer for any works you have carried out on this circuit?
Is your customer aware you dont know what you are doing?
Its a favour for a friend. To help me expand my knowledge.
Have you wired up these lighting circuits or were they already there?
If they're new circuits, you'll have to notify "The Council"! :smilielol5:
Don't hold your breath, the OP has ignored my questions!
So....... lets just assume its new and work from there
