U
uksparks
Hi,
you know that thread about running 100m of cable on a farm and it works out at approx 70mm.
just thinking out loud here, how would you terminate 70mm into a consumer unit? Clearly you can't, so what would you use? I was going to say a switch fuse but that's not appropriate.
its not a problem I have come across to be honest.
also you would have the same issue at the supply end.
