O
OggyMac
I am currently planning on changing the Consumer Unit in the Boiler Room of my home. The board is 17 years old, fitted with old cartridge fuse holders. I am planning on upgrading to a new amendment 3 (bs7671 - 2015) standard. The problem I am having is that I have no experience of working Live, the incoming tails from the meter box have no means of isolation. They are connected into Black connector blocks just before the Consumer Unit and then doubled together in both connectors and are connected on til 2 80A RCD's. If I can get the tails safely isolated, I know how to do all the rest.
Can anybody here advise me on what my safest option would be to give me peace of mind?
safest option is to get a qualified electrician.
I will try get a local electrician to seek help from, or ask the DNO to come out and fit an isolator to allow for future changes
Hi OggyMac, welcome to the forum, looking at your profile and previous post it seems that you have been involved in other area's of the electrical industry and no doubt you are know that field very well, as domestic isn't your field, you may be better working along side a seasoned spark for a few yrs until you pick things up.
If you want to get a spark in and ask him to make the final connection and check your work that might be the best option as you will have done your first board change and had it checked with obvious pointers from the spark on any issues he finds (if any).
I think that would be my best bet, I do agree with you on the experience front, I previously worked for a company wiring the Ulster Hospital in Belfast a few years ago but because it was a new build/renovation to an existing building I never had to work live, I like doing dist. board terminations as i had the patience to do it right. I will stick to your advice anyway, thanks!
