Not likely to be used at once I wouldn't have thought.
And the each will have their own power use pattern, so you'd need to be unlucky to get all 3 running and running their max current at same time.
FWIW at mine it turns out kitchen and utility room was wired on one RFC and it supports kettle, toaster, micro, dishwasher, washer, dryer and a big fridge. I've not said anything to family and they just get on and jam. I did confirm it is a proper ring and the mcb is not cooked, yet :)
we got all that (except for washer/dryer) plus half the downstairs sockets all on a 16A MCB radial. never tripped except when a vivarium heat lamp blew and took out the MCB.
My house had all sockets on a 16A MCB for long enough, and tbh I can't recall having many trips.
I can't find a 7671 regulation and my IET builders guide says if the appliance can be pulled out then the plug and switch behind is ok. So common sense applies ? (not make life tough :))
Piratepete,
Rpa07,
