K
kingeri
In that case the ring itself would be overloaded and hence unsuitable to connect these loads to.@kingeri Yeh but those machines may all be rated at 3kw if they were going at the same time...maybe marginal though
Not likely to be used at once I wouldn't have thought.
we got all that (except for washer/dryer) plus half the downstairs sockets all on a 16A MCB radial. never tripped except when a vivarium heat lamp blew and took out the MCB.And the each will have their own power use pattern, so you'd need to be unlucky to get all 3 running and running their max current at same time.
FWIW at mine it turns out kitchen and utility room was wired on one RFC and it supports kettle, toaster, micro, dishwasher, washer, dryer and a big fridge. I've not said anything to family and they just get on and jam. I did confirm it is a proper ring and the mcb is not cooked, yet![]()
Why do you need isolators.
Personal preference I would say.Presumably the sockets are going to behind the white goods...... So isolators are needed if you ask me...
But the mcb should be accessible to isolate if neededA socket behind a Washing machine is not accessible ......
)I don't believe BS7671 define accessible.But when the RCD starts tripping you need accessible isolation to eliminate such appliances.....
