T
The Ghost
Wylex-rewirable fuse bridge x 5 CCT Cooker/Ring/radial sockets/Up lights/down lights So far everthing checked out apart from half the ring grd flr had gone into melt down. Removed that half left the other (good) half in as radial pro tem fused to 20a. (Down from 30a) So IR on bad part of ring .02 Mohm tumble dryer thermostat I think caused the melt down. Rest of ring (separate job) to be made good. IR on good part >999. Zs is good on lights/cooker/sockets what could go wrong?
So price for just a box change. Bonding in place to gas and water measures good i.e. <.05 ohm.
TN-C-S Tails are fine DNO equipment good. Enough cable to reach replacement box. Possibly go RCBO as there are five circuits. Just some minor other defects like broken socket/loose sockets. Just want a sanity check on price of around £500 for box change. Disregard any other work mentioned.
Use and Control Gear / Wilts CU with RCBO's and you'll make a decent margin...
e.g. 8 way populated board (6 x RCBO's) included .....or £106 inc VAT.
