Soulsurfer
612
165
118
Channel Islands
Business Name
M.B.S ELECTRICAL
Hey all, after a strong light / non cheapy laser to project horizontal & vertical lines for downlights and metal boxes etc.. my mate from up North just got a green one for his ceiling fixing company think was a Hilti, said was £600 plus but long distance and apparently much better in bright light than red ? But not spending that kind of cash ! Dewalt ones seen a lot and around £180 here, any other opinions on them ? Cheers.
I've got the Dewalt 088k, can't go wrong with it. It's got a magnet so you can stick it to the metal stud in plasterboard walls. Got mine for around £130
Reactions: Soulsurfer
Most use the deWalt. I've a deWalt laser and spotter. The Hilti rotates whereas the deWalt has a solid red line.
Think the ceiling boys use Dewalt with the magnetic / clip on brackets I think, might be on offer at moment for £120 odd but didn't know if bright enough but should be I think, thanks all
I have only owed the Bosch range of which have served me well. In recent months I purchased the GLL2-80PBMCC of which gives 360º for both horizontal and vertical projection of which I find more useful. A little pricey, but depends how much you use them I suppose. It has a 40 mtr range and also comes with a decent case and universal mount. About £330
I don't think the line lasers are suitable for large ceilings, I see a couple of Polish lads use a DeWalt in a supermarket refurb a couple of years ago in Ramsgate. It was all over the place. If I were installing ceilings of any size I'd prefer a water level over the the cheaper line lasers.
I bought a Stanley Fat Max SC-LD from this company; Laser Levels Online - The Laser Level Specialists - Online Store - http://www.laser-level.co.uk/
Quite a good web site with pics of what some of the lasers can do. I went for the Stanley as you can lock the cross lasers and sit it on its back to project a grid on a ceiling (useful if your marking out a load of down lights), laser dots and price.
Green is better than red laser, if you intend to use in daylight, but pricier.
Also research if you can get spares for you chosen laser. I had a Bosch, which was rendered pretty much unusable after I cracked the glass lens, with no spares available.
I think you'll find that it was the users rather than the level that was faulty or inaccurate. My DeWalt is spot on.
It's easy to check the horizontal line. Just put the level on a solid surface facing a wall a few meters away. Make a mark on a wall at that LH end of the line. Now rotate the laser to put the middle of the laser line on the mark and check. Then rotate again and check the RH end of the laser line. It's easy to see if the self-leveling is out. Obviously, the further away the wall is, the more that any out-of-level will show up.
It might have had more to do with the spread of beam over a distance plus inability to see it clear in strong light, who knows?
They are certainly not that accurate over long distances.
The DW087K is specced at +/- 0.3mm/m, so 3mm at 10m. Whether you regard that as inaccurate will be down to the requirements of the job. For most electrician's work I would have thought it would be good enough. And, generally, you won't have one that's right on the limit.
For electricians they are great, I have two, but just dont think they are the right equipment for ceiling fixers - that do large ceilings.
Fair enough.
Just getting the DW089KTRI - laser line 089 plus a tripod in a nice sturdy case. Great piece of kit but not cheap.
Buy cheap buy twice!
Soulsurfer
Channel Islands
Business Name
M.B.S ELECTRICAL
Self Levelling laser what's decent ?
Electrical Tools and Products
Soulsurfer,
Toneyz,
