Been doing some DIY at home on my week off, found 2 of these after removing a section of ceiling. Not entirely the boarders fault, the thick electrician has drilled all the holes at the bottom of all the joists...
that's quite a novel way of cable restaint.
Safe Zones outside?
Why not Pete outside light creates one outside? Building inspectors just looked at one I did that's going to be rendered over, never said anything.
And the even thicker boarder has shoved the screw straight through it, would still have hit the cable even if it had been higher. Some of these other "trades" just go hell for leather like maniacs.
And the even thicker boarder has shoved the screw straight through it, would still have hit the cable even if it had been higher. ALL of these other "trades" just go hell for leather like maniacs.
corrected that for you.
Main Neutral Heated to the point consumer unit was smoking and the cable had been completely disconnected from the part in the terminal block.
I wonder if it had become loose or a high resistance developed in the main switch and got worse as it will, nasty !
Those old MEM boards were usually ok.
