Darkwood
Safe Zones outside?
Why not Pete outside light creates one outside? Building inspectors just looked at one I did that's going to be rendered over, never said anything.
Been doing some DIY at home on my week off, found 2 of these after removing a section of ceiling. Not entirely the boarders fault, the thick electrician has drilled all the holes at the bottom of all the joists...
And the even thicker boarder has shoved the screw straight through it, would still have hit the cable even if it had been higher. Some of these other "trades" just go hell for leather like maniacs.
And the even thicker boarder has shoved the screw straight through it, would still have hit the cable even if it had been higher. ALL of these other "trades" just go hell for leather like maniacs.
corrected that for you.
I remember fitting a few around 1987-88 ish, they were quite good at the time and used to have a sticker stating they had a design centre award or something like that.
So long story short... got a call from an existing customer about an immersion heater in a rental property she owns. Gas man/plumber had told her she needed a new immersion. Checked immersion element, fine, thermostat, fine, mains in, fine, but no current flowing. CU was about 2m away, so continuity checked all conductors... line, fine, cpc, fine, neutral, nothing!
I'm thinking to myself 'I just don't get it', cable is about 3m long, no signs of damage, connections to everything fine. So starts pulling in replacement and then finds it shoots off down the other end of the property. I missed that on my initial survey as it was buried right in the eves.
Toddle off to the kitchen at the other end of the house where I find another immersion heater switch (for convenience I guess, having to walk about 5m is such a hardship). So I opens it to reveal this:-
Gas man/ plumber pulling a fast one - wanted a bit of work but . . . He wouldn't have been there in the first place unless there was a fault! The plot thickens dum dum dum!
What I failed to mention was the neutral was out on the switch near the tank as well, which I obviously fixed before I did a continuity check on the cable. On the switch in the kitchen however, the terminal screws were knackered and couldn't be undone... both of them! Coincidence???
Put a Wago lever in on the neutral in the kitchen as a stop gap while I sourced a new switch plate, now I have one I'm waiting for the landlord to get back to me to go and fit it.
As to who did it... god only knows. It was the gas man I think who got her to call me. Tenants reckoned they had been using it until a few weeks before, but the boiler condensate drain was blocked so that was off and they wanted a hot shower and found it wasn't working. They couldn't remember if anyone had been in other than the gas man and me, neither could she.
I'd love to know though even if just so if I'm asked by a customer for a recommendation on a plumber or gas engineer I can avoid giving the guy work. Not that I'm complaining it was easy money apart from the cost of fixing my mistake of pulling of the cable somewhat prematurely, which I didn't charge her for. Have to say it freaked her out a little bit, didn't do a lot for me either... wilful sabotage that could so easily have killed someone, and I'm there with one of the tenants, I'm thinking any minute now we're gonna get the Psycho shower scene in the airing cupboard :eek:
One more. Can anyone spot what's wrong with this? Apart from the obvious ratsnest chocblock fetish the installer had. I should add, it was dubiously concealed under the mass of insulation you see behind it. I went hunting after some basic checks threw up some interesting results during a quote visit for some lighting changes :)
8K
Darkwood,
UKMeterman,
