A
acvc
HI there.
I've been asked to move a consumer unit from above a floor to below a floor (in the basement, still accessible). It's a move of about 1.5m.
While I would like to upgrade this to an Amendment 3 compliant consumer unit (thereby requiring full testing), the customer is telling me that this is not necessary because another electrician quoting for the same job "has said so".
Do the Regs require it???
Many thanks.
You will be installing a new consumer unit, even if it was the one that you just removed (in my view). You will have to completely remove all circuits, disassemble the CU etc. To me it is a CU change. Notifiable and must be up to current regs, i.e. "amd 3 compliant". Others may disagree.
Are you in a scheme, ask them? If you moving said CU, and not replacing it, you could argue the case. For example, if you moved it a few inches up or down etc, don't think it would need replacing with A3 CU. Moving it to different room, dunno?
This is a good question this, agree with Midwest move it a bit either way who cares, move it to a different floor 1.5m away then it must be metalclad ?
Scheme providers may well say metalclad, maybe I would but the board is not being replaced. I would say there is good argument to reuse the old one.
If the description of works carried out that you write on the certificate says
"Changed consumer unit" New metal clad or a cupboardy thing to enclose the plastic item needs be
"Re positioned existing consumer unit" ,then plastic it shall be,that would be the extent of the works that is what gets done
Maybe we ought to take account of needless cost being inflicted on a householder and for what benefit
