Discuss copper conduit possible or not in the UK Electrical Forum area at ElectriciansForums.net
Knowing the excesses of the house of lords and the gravy train that is parliament it was probably gold gilt and over time been worn away!Did you know that copper conduit was used for the wiring in Westminster Palace?
Use a stock and dye on the copper tube and fit your bush, couplers and Earth after.will just be a few straight stabs of it going from a socket straight into plasterboard ceiling- so can earth the glav conduit through using a coupler and bush and fly leading the back box- but how would this be done if using copper pipe? is there a simular thing to a bush+coupler for copper pipe?
there will be no accessible place to be able to bond in with out it being on show and look crap lol
Somehow don't think a regular set of conduit stocks and dies would work very well on copper tube.Use a stock and dye on the copper tube and fit your bush, couplers and Earth after.
I have done it woth PVC, Gal.steel and copper, all works.Somehow don't think a regular set of conduit stocks and dies would work very well on copper tube.
Must be very lucky then.I have done it woth PVC, Gal.steel and copper, all works.
Yep. I wouldn't be trusting those threads.Must be very lucky then.
That's a lazy estimation.No luck was involved! Knowledge and know how, SMH.Must be very lucky then.
What's next....same set of s+d's for us and them(plumbers)?
.......boom, boom and spray? And what are you the holy grail of?
Oh right I stand corrected! do tell please.That's a lazy estimation.No luck was involved! Knowledge and know how, SMH.
Glad to hear you're wearing your orthopaedic shoes today. Surely you know how to use a S&D, respecting different materials, gauges and CSA.Oh right I stand corrected! do tell please.
What are you on about?Yeah, that's right, I'm a miracle worker because I may know or have done something you haven't which is still compliant.
Jesus, someone's rattled your sandals..Yeah, that's right, I'm a miracle worker because I may know or have done something you haven't which is still compliant.
Reply to copper conduit possible or not in the UK Electrical Forum area at ElectriciansForums.net
