Discuss copper conduit possible or not in the UK Electrical Forum area at ElectriciansForums.net
will just be a few straight stabs of it going from a socket straight into plasterboard ceiling- so can earth the glav conduit through using a coupler and bush and fly leading the back box- but how would this be done if using copper pipe? is there a simular thing to a bush+coupler for copper pipe?Copper Spraypaint maybe ?
I have saw some knocked up copper light fittings and personally don't see any problem with using 22mm copper pipe as containment as long as its adequately earthed.
But I could be wrong perhaps there is some reg lurking somewhere which I'm not aware of prohibiting the use of copper pipe etc.
there will be no accessible place to be able to bond in with out it being on show and look crap lol
solder or compression fitting ?
Pete999 is an expert for that.Polished MICC...
water would also freeze in steel conduit.Would there be a thermal consideration to consider?
Water freezes in copper pipes outside. Would PVC twin and skin be ok in copper pipe when winter hits -10 and beyond?
Unsheathed MICC.
Reply to copper conduit possible or not in the UK Electrical Forum area at ElectriciansForums.net
