J
Joenicholson1996
Would it be possible to use a multi core SWA cable to run both a 230v supply to a certain area and also run several camera signal cables (both the visual and the earth/neutral) down the same SWA cable, or would having an AC current running down the SWA cause any interference to the cameras signal due to the armourings.
I ask this as it would save time in the future instead of running individual coax cables for each camera.
Cheers
Cheers
