S
Squid
Tried them out yesterday as I had a couple of Wiska boxes to attach to a garden wall, tell you one thing they too the job.
£6.50 per 100 + VAT from TLC.
Bought a box for clipping wires with metal clips to prevent collpase in event of fire in my dads pub. Havent done it yet.Tried them out yesterday as I had a couple of Wiska boxes to attach to a garden wall, tell you one thing they too the job.
Lol same here but drill hole insert plug hammer plug in ¼" so the face of the brick doesn't crumble away, saves time.They work for me...I love 'em!
Mind you, I am happy with the old way too...wall plug and good screw...but where you want fail-free, non-combustible fixing, they are very good.
No real reason not to use them...except I have a million plastic wall-plugs to use up...
Need a larger range ... ... torx.
Thanks, stuck them on my watch list, you can never have enough wall fixings...........These are TIMco ones with a torx head...
COUNTERSUNK MASONRY SCREWS TORX MULTI FIXINGS CONCRETE BRICK STONE WOOD FIX ZINC | eBay - https://www.ebay.co.uk/itm/201628694959
with that approach, you will be well sorted for barrats new build. speed up window fixing by 100%.Agreed! You can never have enough! Was working on a refurb yesterday where we needed to have temp wooden screens over doorways...
Drilled wooden battens with multi-purpose drill bits, straight through into the brickwork, hand screwed wall plugs halfway onto turbo-ultra screws, inserted into hole in timber and simply hamnmered them in, then ran them up with an impact driver...sorted! Cheapo hammer frame fixings!
You eating in to your Rum Rations.........100% Tel? Not really, cos barratt only use 1 per frame, I use 2!
Heads are a little dickie on them I think once in fixing is 2nd to none
PH heads is probably why.
