Discuss Dewalt Wall Dog Screws in the Electrical Tools and Products area at ElectriciansForums.net
Tried them out yesterday as I had a couple of Wiska boxes to attach to a garden wall, tell you one thing they too the job.
£6.50 per 100 + VAT from TLC.
Bought a box for clipping wires with metal clips to prevent collpase in event of fire in my dads pub. Havent done it yet.
Did have a play putting a few in a wall after i bought a pack and they hold good and tight. Certainly worth the money. Saves putting plugs in aswell.
They work for me...I love 'em!
Mind you, I am happy with the old way too...wall plug and good screw...but where you want fail-free, non-combustible fixing, they are very good.
No real reason not to use them...except I have a million plastic wall-plugs to use up...
Lol same here but drill hole insert plug hammer plug in ¼" so the face of the brick doesn't crumble away, saves time.
Need a larger range and a head like the Kreg screws or torx.
Agreed! You can never have enough! Was working on a refurb yesterday where we needed to have temp wooden screens over doorways...
Drilled wooden battens with multi-purpose drill bits, straight through into the brickwork, hand screwed wall plugs halfway onto turbo-ultra screws, inserted into hole in timber and simply hamnmered them in, then ran them up with an impact driver...sorted! Cheapo hammer frame fixings!
with that approach, you will be well sorted for barrats new build. speed up window fixing by 100%.
The Rawldogs are brilliant but I do hate the Phillips though - keep the bit with the screws now...
I've found the white headed ones to be a pain as the white coating messes up the Phillips slot
I have a pack of the white ones - only used them to fix a stair bannister to a wall (the brackets were white) worked a treat but I do recall having the same issue.
Reply to Dewalt Wall Dog Screws in the Electrical Tools and Products area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
the romex wire itself isnt stripped. you just treat it like cat 5. with a "call for a quote" price to buy the tool. I ran into t these in a mobile...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
