W
Wilko
Hi - the new "one way consumer unit which had an RCD" also had an MCB in it? This means (to me) there are now two circuits where there was one, each with its own earth loop and ADS times to be met.
Going with that analogy Wilko, if and I say if the OP had swapped the shower switch with a RCD / FSU instead of a small CU, would that not be similar, or the same as using a CU, after all, all he is doing is fusing down via the CB and adding a RCD? it's an imponderable I guess, which can/could argued either way, well that's how I tend to see it.Hi - the new "one way consumer unit which had an RCD" also had an MCB in it? This means (to me) there are now two circuits where there was one, each with its own earth loop and ADS times to be met.
.Just like some TV detective show we need a Poirot type or the Guys from Hunting HitlerOh dear, thought I had a handle on this one ... more to think about.
.Lateral thinking Wilko.Oh dear, thought I had a handle on this one ... more to think about.
Really bizzare..putting an RCD on a shower when there wasn't one there before..what was I thinking??Overall it seems a bizarre thing to have done.
You haven't wired a new circuit, you have altered an existing circuit MNWThis is a EIC in my opinion. The supply to the shower isolator is now a distribution circuit.
Also the shower isolator did not burn out because there was no RCD installed.
I agree, what were you thinking. Straight forward replacement switch with a departure on the Minor Works additional rcd protection not provided, existing circuit.Really bizzare..putting an RCD on a shower when there wasn't one there before..what was I thinking??
Sorry but I like to add an RCD if it's possible.I agree, what were you thinking. Straight forward replacement switch with a departure on the Minor Works additional rcd protection not provided, existing circuit.
