Dodgy Dave has been doing the rounds again. These are all in the same place. Where do I begin
can fit your finger through every one of the holes on the top surface no protection for the cables entering the bottom or the side dodgy set up where that 2.5 t&e’s nuetral feeds something else in the CU god knows why old heating box tails enter two different holes unused holes in the old heating box that you can stick your finger in random unprotected joint down below CU.
Oh and the MCBs etc haven’t been fitted correctly so there is half a device’s width at both ends of the CU with no blanks aaaand a lovely pokey up bit of uncapped busbar just waiting to zap you if you try and reset your tripped lights in the dark and put your finger through the hole. What a mess...
