J
Jengajenga
Hi all,
I have stupidly drilled through the same electrical cable TWICE 1 inch apart. This is above a twin plug socket which obviously now doesn’t work. The holes are about 1m above the socket.
As a temporary measure I was going to connect the wires individually with Wago connectors but the 2 whole problem has thrown me!
Will it be okay to replace the broken part of the cable and use wagos at each end?
Or is it better to replace cable from the break to the plug socket (so just one set of connectors being used?) Is it a case of attaching a new cable to the end of the old one and greasing / pulling through the socket?
Hope all that makes sense. Advice much appreciated!
