Guest viewing is limited
Sort of here as well!
I got a 20mm sds bit stuck in a stone wall of a house tried the usual tricks and it wouldn't come out sooo I borrowed a heavier drill off a mate and went and snapped the bit off about half way down it. Left half of it in the wall. It must of had a weak point in the bit and decided enough was enough!
Sy
Coincidentally, I bought a set on Armeg impact drill bits this morning and used them to fit a radiator this afternoon.
Really impressed, just having to take one tool can make a big difference with reactive maintenance jobs, especially in city centres.
Anyone ever had a long SDS bit totally jammed in a stone/granite type wall - and abandoned it ?? :D
I was drilling down through my concrete kitchen floor behind the kitchen cabinets to replace the water main and got a 3ft 20mm drill bit stuck but eventually managed to get it free by using a 25mm drill bit and drilling down beside it, at some cost to the 25mm bit, but I had spent two days getting that far and was not going to try again.
last time i had a little drift, was in a gale. mooring broke. boat ended up on the rocks. all goes to prove, if it's got ---- or floats, it's gonna cost.
I sheared off a bit holder in my makita impact driver. I disassembled the chuck and got the broken bit out, but it never went back together the same, the bits kept falling out the end! . Thankfully it was 11 months and 3 weeks old so it went back to makita who very kindly fitted a new chuck!
Glasgow
Flat wood bit stuck in impact driver
JM ELECTRICAL,
weevilward,
