cut a couple of 2 ft. sq. holes in the ceiling and fit 2 of these.
49889
:sunglasses::sunglasses::sunglasses:
A 50W lamp gives off the same heat be it 12V or 230V
If you must fit halogens, fit 230V jobbies
had this argument with a lighting "designer". customer wanted smart lighting, whole house was approx. 120 downlighters. the "designer" specced 12V LEDs each with drivers. my input was "youse going to have problems". customer went with the designer's spec. and now is calling them back in to failures on a regular basis. he called me and asked if i could sort it out permanently. my reply was to rip out the £2000 he'd spent and start again from scratch. was not well received.
Cons.
6 halogens at 35W each (or 50W if you really want to burn your head), that’s 210W.
If they’re sitting under that, they will feel the heat.
Compare that to 6W LED and the energy saved alone will pay for the installation.
Halogens need replaced more frequently.
The heat from halogens can deteriorate the plasterboard ceiling
Pro
As above, halogens don’t flicker as LED do, but that’s almost imperceptable.
Halogens can be dimmed simply with traditional dimmers and newer smart switch dimmers.
LED lamps are still a little hit and miss with suitability.
I take it you mean the LED version of the old 12v dichroic? might of well had the GU10 type.
Sorry that was a reply to Tel's post 26 not got used to the new forum yet
OK , just spoke to the client , he said he wanted 240v halogen spots , citing that led's light is not as good as halogen , we have agreed to fit the GU10 fire rated holders and I will show him both types fitted so he can see the difference !
Aren't these halogens being phased out now?
