The LED light is only as good as the quality of lamp you but.
Cheap Chinese tat - cr*p light
Decent priced from known manufacturer - just as good as halogen
And you have the choice of colour temperature
But my original question was about regs for fitting , not whether or not my client wanted halogen or led spots !
Quite right. And I think we answered that early on.
Everything else has been personal opinions to a posted statement.
If it’s your clients wishes, then trot on.
You did ask us for reasons. post #17
These halogens get to approx 200 degrees C. so keep a distance away from anything combustible i.e. wooden joists and other fabric of the building.
Make also sure that there is no other debris ie rubbish that could cause ignition of a fire.
Consideration of building regulations would be a transmission of sound, fire and air through the hole.
Consideration of building regulations would be a transmission of sound, fire and ait through the hole.
Yes will be getting sealed , fire safe holders .
not to mention if fitted in a bog room, the transmission of fart gases.
Haha. Another thread dragged into the gutter.
Welcome to electricianforums.co.uk..... sorry .net now
My list not to.
Expensive to run.
Run very hot.
Damage plasterboard, heat.
Heat can damage springs so they start to drop down.
Heat can damage joists.
Rare cases shatter.
Forever changing lamps. Good luck with that if the heat has deformed the fitting and or made the plasterboard so delicate it falls apart.
Can be a fire hazard.
Heat can melt connections and wiring.
In case I forgot they generate a lot of heat.
Wasteful horrible things that are more bother than they are worth for 99.9% of installations.
Wow , you def don't like them do you , there must be millions in homes around the uk ! .
I have them in the Kitchen ( not fitted by me ) for over 4 years not replaced a bulb as yet , they are not recessed in the ceiling though ! .
