Discuss Ceiling recessed down lighters in the Electrical Forum area at ElectriciansForums.net
Consideration of building regulations would be a transmission of sound, fire and air through the hole.
not to mention if fitted in a bog room, the transmission of fart gases.
Haha. Another thread dragged into the gutter.
Welcome to electricianforums.co.uk..... sorry .net now
My list not to.
Expensive to run.
Run very hot.
Damage plasterboard, heat.
Heat can damage springs so they start to drop down.
Heat can damage joists.
Rare cases shatter.
Forever changing lamps. Good luck with that if the heat has deformed the fitting and or made the plasterboard so delicate it falls apart.
Can be a fire hazard.
Heat can melt connections and wiring.
In case I forgot they generate a lot of heat.
Wasteful horrible things that are more bother than they are worth for 99.9% of installations.
Wow , you def don't like them do you , there must be millions in homes around the uk ! .
I have them in the Kitchen ( not fitted by me ) for over 4 years not replaced a bulb as yet , they are not recessed in the ceiling though ! .
Part of the electrical qualification now, and advice in general is to be as eco friendly and “green” as possible.
Therefore, it’s quite common for us to advise on LED lamps purely on their power saving merits.
Reply to Ceiling recessed down lighters in the Electrical Forum area at ElectriciansForums.net
