Discuss Ceiling recessed down lighters in the UK Electrical Forum area at ElectriciansForums.net
Hi
Tks for reply , not actually got them yet , as far as I know there is no insulation in the ceiling and they will be fitted in the lounge .
Just was not sure if there was a reg covering the installation of these .
spike
Fitting LED down lights closer to a surface than manufacturers recommendation, can cause them to overheat and fail. Same as covering with insulation, unless specified by manufacturer as suitable.
One thing about led lights that most people don’t realise is they flash.
Now a halogen type light will get slightly brighter and dimmer as the 50Hz cycle passes through the element heating it and allowing it to cool slightly.
Because of the reaction time of the element, it never turns off, just dims a bit.
Light emitting diodes can turn on and off at high frequency, going completely off between cycles this is why they are used to transmit high frequency digital data down fibre optic cables.
With all but some very specific types of led lamp, they are turning on and off at whatever frequency the driver circuit is providing.
This is regularly demonstrated on top gear, when they slow motion a car you will often see that the headlights and tail lights are flashing.
There are some study’s that show this type of lighting is bad for the brain and can affect people with a epilepsy.
Tks guy's for your replies , it seems that they want halogen lights not led !
If your customer prefers the light output of halogens over LED, they should give these a try:
I fitted them in our kitchen and utility room-they give a really nice quality of light that is very close to incandescent lighting. They have slightly lower lumens per watt than a lot of other LED GU10s so the downside (besides price!) is that you may need a few more fittings to get the right light levels.
Reply to Ceiling recessed down lighters in the UK Electrical Forum area at ElectriciansForums.net
Hi, want to installed some LED strips in the ceiling and wanted to know how the recessed LED profile is fixed in place and stop the plasterboard...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Hi. Looking for some guidance please as I’m wanting to replace a ceiling rose fitting into a ceiling pendant. Done this many times but never come...
