Not strictly needed, but I would bring the board down the wall a bit to a more user friendly height. With trunking to hide cables.
or chase them in. then CU on a bespoke piece of board, spaced off wall with 4 bits of 1/2" long 20mm pvc conduit . then rear entry.
Everyone seems obsessed with rear entry on this forum. Nudge nudge, wink wink. say no more, guv’nor
Why do we fit RCDs for stuff buried in a wall less than 50mm deep if not to guard against things that aren't "normal use"??
Or use a stand off bracket rather than battening. Many manufacturers sell them.
And I generally space the board off a little with a couple of pieces of small batten the same height as the board to facilitate this.
I do rather hate mixing pieces of organic matter with metal. Just doesn't seem very karma to me. What about plastic, or even some manufactures spacers. :)
I bloody hate people who do rewires and still put the new board back at ceiling height....especially when its in the smallest cupboard they can find....even more infuriating to finallt get the cover off to find a birds nest
Hey all,
I have just finished a rewire of a 1 bed house and just have the board left to install. I am a qualified sparky but now work as a project manger so haven’t carried out much domestic work in the last couple of years. I know that the requirements for installing consumer units has now changed and am wondering what are the requirements with regard to cable entries into the board. I have the cables all dropping down from the ceiling where the existing board and meter position is in the entrance hall. Any advice would be appreciated.
I think you must do short course called part p etc ???
Thanks for all the replies. Looks like back entry will be the best way to go.
On a side note I’ve seen online that suppliers are selling the semi blind grommets which it says are ip66 rated for use on cu’s. Would these comply with the new regs as I haven’t seen this method shown anywhere?
Cheers
Not sure thought I read something about it but I must be thinking of something else
Last point the existing tails are 16mm which will be fine as there will be little load being used. Anyone know how much roughly the DNO charge for coming out to pull the main fuse and back to reinstate supply after? It’s wpd here.
Have you consulted the seal fairy??
longers30,
Charlie_,
