Looks like the final scenes from The Bridge on the River Kwai.
Changing Pirate's name to Robinson Crusoe....?Looks like the final scenes from The Bridge on the River Kwai.![]()
Got called out because a light wasn't working...Been banging on about the need to change all the floros with LEDs for a while this might speed it along a bit.
Good point.....it's contained to a degree.Got called out because a light wasn't working...
Says it allThere was a hole melted into the diffuser too that no one had noticed.![]()
could you not have soldered the wires on to the tube pins?Yep, nice new twin led anti corrosive now in its place.
Looks like that might not have been needed...no MIG welder either.could you not have soldered the wires on to the tube pins?![]()
The ballast was burnt out for the other tube.could you not have soldered the wires on to the tube pins?![]()
