Looking at the photos, there is an upstairs room?
At first I thought the outside photo is of two storeys, but looking again, I can see guttering half way up the wall, so the extension must be single storey with a flat roof.
Just possibly a (re-fillable) hole in the ceiling will give access to the cable(s) and they'd be loose e.g. under capping or in oval conduit, or even loose under dot/dab plasterboard. Or the cable(s) could be firmly encased in a bonding coat of plaster, having been clipped to the wall.
Would help to know the wall construction and cable installation method before making any holes anywhere.
I have stupidly managed to drill into a light switch cable. I’m trying to keep cost down as much as I can. Would chasing them wall out ready help?
Buy one of these. Excellent tool. Enables you to trace the wires and metal pipes in the wall. I never drill a hole without it. Can save a lot of grief and shredded nerves. Especially when you're on someone else's property.
Get a sparky. Without digging cables out and pulling new ones I would look at a Quinetic switch to the light. No mess and you can put your shelf up exactly where you drilled. Using these more and more to keep labour costs down. This versus chasing cable and filling is way easier.
