W
wicherkowo87
Hi guys.
Electrician will soon rewire my kitchen and some questions arises about sockets and isolator switches.
I think they look ugly and don't want them on sight.
Is it possible to install only two isolator switches one for oven and hob, and the second for electric instantaneous water heater.
What about fridge freezer, washing machine, dishwasher, microwave oven, and fan extractor do they need isolation? Can't there be just plug behind appliance? Or maybe one isolator for all of them?
What you are trying to avoid is not being able to isolate or an appliance because the appliance itself blocks the means to be able to isolate it. This is a particular problem with integrated appliances.
You could have a single position to isolate appliances from, google kitchen grid switch.
You could have sockets and isolators in cupboards as long as they are accessible and free from potential damage from use of the cupboard.
You could even have a central isolating position within a cupboard if the layout suited it.
Cooking appliance isolators are always best readily accessible above worktops.
A quick and obvious means of isolation can be a life saver, I would not hide them away because it looks better.
Imagine having just put a load in the tumble dryer, turned it on and 3 min later, smoke starts coming out of it.
An easily accessible and identified isolator will save you precious time, not having to remember what cupboard the switch is in then pull all the pots and pans etc out to get to the switch whilst the room fills up with smoke.
end of the day, a kitchen is for cooking etc. it's not a fashion statement to impress the neighbours.
[automerge]1589020528[/automerge]
our kitchen is longish but narrow, more like a galley. at least Mrs. Tel can reach both hob, coffee pot, and sink simultaneously, not like some of these modern kitchens where you walk a mile between appliances.
Put them all in a larder unit, with a panel brought forward so it's easy to access and see what isolator does what (as long as they are labelled, obviously).
I'd usually do about 30-40 kitchens a year and this is the most popular way of installing them by far.
As mentioned many times before, there is no regulation whatsoever that says you must have isolator switches for as nothing in a kitchen.
as above, good access to the socket and plug is necessary, it’s hard to move a washing machine, to get at the plug, when it is full of water and wet clothes.
In Scotland the building regs require it.
For the OP.
You can make them less hideous but not by much.
This is what mine look like to give you an idea.
On the RHS is what the grid would look like with SS switch modules.
For the OP.
that worktop is far too clean and tidy. is mrs. ferg. on strike? :p :p :p
Hi.
This is the best idea I've seen, where do you buy does switches witch appliances name's on it and what they called?
Hi.
It's called a grid switch.
Your electrician will be able to source them for you along with all the other materials.
wicherkowo87,
Andy78,
