C
Car123
I had an EICR done in 2014. Some loose trunking on a wire to the showers self isolator based on the wall was graded C3. In an EICR done this week the same trunking in the same condition was graded C2. This seems a bit over the top please advise
What do you mean by loose trunking? Is it not secured to the wall? If not then can you just glue it?
I expect you can just glue it. I rent the house. But the electrician is quoting for work as a C2 and my question is whether it should be graded C2 or C3
Doesn't matter what code, just get it secured. Take less time than finding out what the code should be!
Well I don't argue with that. But nonetheless I would like some advice about this coding. The trunking is not hanging off its just not attached solidly to the wall. By grading it C2 the electrician does not pass the EICR and I have to pay him to come back. I am looking for guidelines on this grading
There was a change in the 18th edition, associated with premature collapse of wiring, under this all cables must be properly secured with fire resistant fittings (or other physical means), if this is not present, then it's a C2.
Just gluing it will not satisfy the regs.
Would that only apply to a new installation ?
Sounds like you need it fixed with something that is heat-proof like a metal clip / stainless cable tie, etc. Any photos possible so folk here can suggest solutions?
If you are quoted under £50 to fix it probably simpler and easier to just get it done, as often buying a box of 100 clips, etc, will be the best part of that anyway.
May sound a bit harsh here but....if you are renting the place what do you care about c2 c3 et all?
When was the 18th edition brought in. This may explain the change in grading. Interestingly though the electrician who did the original EICR told me that it was not necessary to do anything. It looks quite stable to me
True, but realistically it may just be a short length of cable above the bath in the corner of the bathroom. Never going to cause an issue with access.
