So what do you in that instance?
I've had occasions where I've had to hold an MCB together at the top while tightening, which isn't a great advertisement for the quality. The ideal would be to re-tighten a week later I suspect, but that's usually practically not an option - I do often tighten - energise, then re-tighten as the last thing before the cover goes back on though...
Been Youtube'ing today and found a page called Efixx. They were demonstrating the use of ferrules and a ferrule crimper. Not something I have ever thought about using before as I tend to use solid core conductors up to 4mm and pre-wired Klik flexes for lighting installs but definitely looks like they would be a handy addition to have on the van.
Anyone use these often and for what uses?
I wonder if all these sparks who now use impact drivers on consumer units check their terminations
I use ferrules on almost all stranded cables... Both insulated and uninsulated ones.
Am curious about the Armeg "impact" holesaws. In what way do they differ from standard holesaws?.
On a separate note, I recently was alerted by a poster here to a multitool blade for cutting plaster and brick. The pictures of the cutout box looked really neat. That's the next buy on my list
Don't waste your money on these. I had a set a few years back. The 20 & 25 lost all their teeth in no time at all. The 32 now spins so is next to useless. The box is handy though!
I buy Reisser holesaws now whenever possible, they put most other brands in the shade.
Been on efixxx YouTube channel (AGAIN).
Saw them using a locknut spanner to hold the locknut inside an isolator, DB etc while making off SWA glands - had never seen one of those either!
Can sometimes be a pain in the posterior trying to fit gland pliers or an adjustable into a small isolator or box with a lip to hold the locknut so one of those looks like it could save a bit of blaspheming!
Anyone know where to get them? Only managed to find one on amazon for £27 which seems expensive.
IAmSparkytus!,
nicebutdim,
