Guest viewing limit reached
Zdb
I don't suppose anyone has put together a spreadsheet with a table of torque settings for popular/common brands/devices?
Hoping to save some time if it's already been done and shared here
Many thanks
TBH you're better off checking up to date manufacturers information as things do change. A generic crib sheet off the net will never be updated and you would need to check for accuracy.
Had an instance a few years ago where the manufacturer originally stated 2Nm for their MCBs, NADER IIRC, but after a small fire they increased the setting to around 5Nm.
There’s normally a sticker inside “quality” consumer units with torque settings for mainswitch, mcb, rcbo neutral bar etc.....
from memory, mcb are 2.5, bars are 3.5???
which is fine, but my torque Wiha has marked numbers of 2.2, 2.4, 2.6 etc.
I need to set it half way between marks to get a point 5
This is one that is floating around the web. Not my work but gives a good base
Thanks. I notice that Schneider and Eaton were missing so I have attached them below for anyone that might find it useful
Zdb
UK
List of torque settings
Zdb,
nicebutdim,
