E
Electrics
Because specs and figures aren't relevant if the batteries don't hold charge and the chucks come loose etc.Much depends on the tool in question. Makita LXT drills range from the DHP453 with around 40Nm of torque and internals made from cheese, right up to the DHP486 with a wrist shattering 130Nm of torque and all metal gearing - how exactly do you manage to tar these two drills with the one brush?
What i'm looking for in a tool is that they're reliable so i can actually count on them to work when i need them. No good having 'wrist shattering torque' if the batteries start to die after a dozen cycles or the chucks are coming loose and need replacing. You could argue this is a battery problem but imo a tool is only as good as its battery since without them they are ornaments.
I had the Makita cordless and impact driver, and the circular saw and they were rubbish and real, real expensive. My opinion is based on their top of the range stuff. It's rubbish.
