That is a new one on me. I wonder how the fuse effects the electronics.
You'd be surprised what hifi enthusiasts do. Have a web search for hifi mains plugs, IEC leads, etc. And check out the prices.
So there!
Why would you need a solid link in the plug of an integrated appliance? Besides you don't buy solid links you just cut the head off an m6 screw/bolt, everyone knows that.
To avoid an uncessessary inaccesible fuse behind.
Yes, many do know that. But a purpose made item is better.
You can get a solid fuse replacement in other sizes, mostly much larger, though I did notice a 20x5mm size:
"A solid fuse replacement slug, 5x20mm used to remove/replace a fuse terminal fuse with a straight-through option. Solid links can be used when trying to trace a fault in part of the electrical system."
Haven't seen any in BS1363 size.
Not a manufacturers item for sure, but looks safe enough if well clipped in making a sound electrical connection. And to regs if the plug is after an FCU. Nicer to have a purpose made product.
Which proves you are trolling again. Surely everyone knows this right?
John-SJW,
westward10,
