That is a new one on me. I wonder how the fuse effects the electronics.
You'd be surprised what hifi enthusiasts do. Have a web search for hifi mains plugs, IEC leads, etc. And check out the prices.
Russ Andrews in particular being good for a laugh.....You'd be surprised what hifi enthusiasts do. Have a web search for hifi mains plugs, IEC leads, etc. And check out the prices.
Why would you need a solid link in the plug of an integrated appliance? Besides you don't buy solid links you just cut the head off an m6 screw/bolt, everyone knows that.Say behind a fixed integrated washing machine. It is not going to be plugged into anywhere else.
Not a manufacturers item for sure, but looks safe enough if well clipped in making a sound electrical connection. And to regs if the plug is after an FCU. Nicer to have a purpose made product.
To avoid an uncessessary inaccesible fuse behind.Why would you need a solid link in the plug of an integrated appliance? Besides you don't buy solid links you just cut the head off an m6 screw/bolt, everyone knows that.
I have the feeling BS 1363 is not BS 1363 once a solid link is pressed in, as the fusing is removed.Anyone got a copy of BS1363 and can look up solid links?
Which Regs?The regs we all have to conform to.
Therefore not permitted for use as it no longer complies. Case close.I have the feeling BS 1363 is not BS 1363 once a solid link is pressed in, as the fusing is removed.
It's not inaccessible, it's behind the appliance.To avoid an uncessessary inaccesible fuse behind.
Why is the appliance, which comes with and is therefore designed to have, blowing 13a fuses in the plug top in the first place?To avoid an uncessessary inaccesible fuse behind.
Yes, many do know that. But a purpose made item is better.
