If you have evidence of point 2 ever being enforced by a manufacturer successfully I'd be very surprised.The thread is about two points:
1) Where to buy solid links for 13A plugs?
2) Manufacturers not honouring warrantees because a moulded plug is cut off to hard wire the appliance or fit a round pin fuseless 15A plug.
Very neatly done too, but there's no live pin sticking out of the other side eh ? ?
Many Sparks do all sorts not to invalidate the warrantee. I am sure in court the makers would lose of an applaince conform to current regs and it is electrically safe and sound. But that is no comfort when the maker is being awkward. Electricians do not want the hassle factor, even if they know they are right, It loses them time and money.If you have evidence of point 2 ever being enforced by a manufacturer successfully I'd be very surprised.
I have provided you with a quote but not received an order yet.The thread is about two points:
Again what Regs are you referring to. Are you ever going to confirm this.Many Sparks do all sorts not to invalidate the warrantee. I am sure in court the makers would lose of an applaince conform to current regs and it is electrically safe and sound. But that is no comfort when the maker is being awkward. Electricians do not want the hassle factor, even if they know they are right, It loses them time and money.
To boldly Troll where no Troll has gone before.The thread is about two points:
Just beat me to it !!!There's ordinary trolling and there's superior-quality trolling that asks relevant and provocative questions which seems to be one of the OP's gambits. In this case even after 85 posts I am not convinced the correct answer has been stated explicitly and while acknowledging the trollish nature of the posting this suggests that it is not actually a 'silly question.'
My understanding is this: To supply or fit a plug or modify the installation of a plug on a domestic appliance in a professional capacity, is to place such a plug or modification on the market. It is therefore required to comply with the 'Plugs and Sockets etc. (Safety) Regulations 1994.' Part I requires that any plug designed to engage in a socket-outlet made to the dimensions of BS1363:1984 must incorporate a fuse-link to BS 1362. Since the solid link does not comply with BS1362, even if the plug complies with BS1363 and the completed installation as a whole provides no lesser degree of safety than it would with a BS1362 fuse-link fitted, the act of supplying the modified plug is in contravention of the P&S(S)R which is a product safety regulation not under the scope of BS7671 and cannot be exempted within a BS7671 departure.
Please do not be distracted by the option in section 6 paragraph (2) '...shall contain or be accompanied by a fuse link...' which appears to condone taping an approved fuse-link to the outside of the plug fitted with a solid link. I do not think that is a valid interpretation.
The Plugs and Sockets etc. (Safety) Regulations 1994
These Regulations re–enact with modifications the provisions of the Plugs and Sockets etc. (Safety) Regulations 1987 (S.I. 1987/603) and make provision for the first time for certain requirements to be satisfied in relation to appliances.www.legislation.gov.uk
Ah ! You've been very creative and borrowed a 2nd neutral pin from another plug ! ?
