J
Jimmyb
hi all, does anyone know if you can fit the new style rcbo into the old style board as i need to upgrade 2 mcb's to rcbo's
many thanks
I am pretty certain that the new Square D rcbo will not fit the older boards like the quickline .
Cheers Chris.
QOE and SQO lovely no they wont fit and to make it worse the QOE are obsolete last quote for an RCBO was £145.00 , if i need one for this type of board i look on ebay ,me to mark hate that dam curly lead on the RCBO
Well i can tell you this. The Square D RCBOs are easier to fit than most of other brands and reason for that is they are shorter than others and it is because the front holes for L and N in Square D RCBO are horizontal, both are in same level. But in most of RCBOs they are vertical, N is in top of L. Couple of weeks ago I installed 6 Square D RCBOs in a CU, there was noway i could fit for instans Wylex or Volex in that CU.
i fitted 14 Square d into a board i must admit they are easy to install then you have 14 curly leads to contend with nightmare , wylex i have done a 14 way to and no problem crabtree no problem volex no problem (having said that they are all the same make anyway Electrium)
so as long as i get ones that are QOE then these will fit
Loool Nike, i think you are not curly fan :). Generally combination of RCBO + Old CU = Headache no argue about that.
no mate thats a standard current ones the older types are RCBO.jpg the qoe
The current breakers that are being sold in screwfix and the like are different to the ones in the link that I posted.
The current ones being sold with the fly leads comming from the top will not fit the quickline 2 boards or a least I could not get them to fit when I tried :confused:
Cheers Chris.
