V
I don’t think the neutral bar should be floating around like that.
Was only replacing it for a usb type. Managed to squeeze some wagos in there. It's a pain in the --- for dead testing having them all twisted like that.yes, thats pretty standard when it comes to old wiring.
Did you get it tidied up? Bit of sleeving? Job's a good 'un
I didn't think of that. I was slightly concerned the wago's weren't going to fit and I didn't have any extension things with me to just hack them off.combi drill in reverse, soon untwist that pile of crap.
Says on here suitable for solid, stranded and flex: Wago 41A 3-Way Lever Connectors 30 Pack - https://www.screwfix.com/p/wago-41a-3-way-lever-connectors-30-pack/755HV?
Almost certainly , intermittent arcing when switched oni'd bet on poor contact of plug fuse .
Nearltly all old stranded house wiring I come across has had the sh!t twisted out of it ...yes, thats pretty standard when it comes to old wiring.
You still get the push fit style Wagos, they have a couple ranges of them at least - the 2273 are newer and smaller, and there still is the 773 seriesYou should always use the lever with a Wago that has that facility, the days of forcing in a cable are a while ago and the old type of Wago, in fact I don't think they make them anymore, certainly I can't find them on their web site, but TLC still have them, in preference I would always use the lever type.
True however with flex sometimes you have to as you tend to get spider legs, I always give em a tug and if they don't pull out then they won't fall out.Pretty sure they should not be twisted after stripping if putting into a Wago?
Who drilled and tapped that set screw into the solder?How much more should I shift this cable.View attachment 99877
