- Reaction score
- 8,215
24v impact would have been the weapon of choice to mangle those massive 3.5mm box screws and lugsThe face fixings screws where probably tightened with a torque screwdriver.
I hate it when tube and trunking is painted the same as the wall..... trunking and tube needs to stand out....its a work of artI do some work at a couple sport centres and when it has been quiet instead of the staff sitting around picking their ears they have been painting all the door frames , conduits , surface trunkings and ever light switches and sockets BLUE to match the walls
When recently on a day trip to York, I amazed my daughters by requesting a visit to Urban Outfitters.I hate it when tube and trunking is painted the same as the wall..... trunking and tube needs to stand out....its a work of art
Go into most modern re-fitted shops like Hollister and they have pulled the old fashion suspended ceilings down you will see lots of galv conduit and tray re-exposed and on showWhen recently on a day trip to York, I amazed my daughters by requesting a visit to Urban Outfitters.
"Why????" they said. "It's the most amazing maze of galv conduit I've ever seen, I could stare at it all day...." I replied.
Sadly I don't have a photo and can't find one online.
It was similar to this but biggerWhen recently on a day trip to York, I amazed my daughters by requesting a visit to Urban Outfitters.
It would be interesting to see how that lot terminates etc.It was similar to this but bigger
Damn i was just about to say 11 in each ...One less termination on LH neutral bar, than outgoing lines on MCBs.
Edit: On the fifth count I can see that's not the case
I was just about to say the same thing................2.5 sq mm T+E hanging off a B32 for oven and microwave?
Correct. I saw that about 30 secs after I took the board cover off.2.5 sq mm T+E hanging off a B32 for oven and microwave?
Forgive me asking, but did you test both IR and continuity to rule out something plugged in?On the socket ring the L-N was a dead short
Yes, and I got them to unplug everything in the kitchen anyway.Forgive me asking, but did you test both IR and continuity to rule out something plugged in?
It's not upside down, just not correctly fitted.And it looks like the Hager blank is upside down.
