N
NUGGY
At risk of feeding the troll
So where in this minimalist installation would you connect the outside lights, the garage, the shed in the garden, the EV chargepoint, the solar PV etc etc
With regard to nuisance tripping one RCBO trips and your cooking appliances are taken out could be a bit inconvienent on a Friday evening or a weekend or is it microwave dinners for a few days until the electrician calls to fix the fault
With regard to cable how many different cable sizes do you carry in stock or carry to site for the few metres of 1.5mm² from an FCU to an outlet plate needed on a job do you carry a drum of 1.5mm² for this or just use the 2.5mm² you have been using on this and other circuits
Please explain how the regs allow this optimistic method of cable and protective device choiceA point brought up in this thread was that expensive AFDDs being mandatory in flats in blocks of 6 floors and over, installation will be cut to the bare bone to save costs, with 1940s/50s levels of scant circuits. They may filter down to all residential installations. But it can be done safely and cheaply...
So let's look at a 3 bed flat on the 6th floor.
1. One final ring with a 32A AFDD. This has no heavy current appliances apart from say a 3kW kettle. Most being TVs and the likes.
2. RCBOs on all other circuits.
3. LED lighting, smoke alarm and bathroom extractor fan has one circuit using 1.00mm cable. 3A RCBO.
4. Heavy kitchen appliances on one circuit. A 4mm cable to a bank of FCUs in the kitchen. 1.5mm cable from FCU to each appliance: w/machine, tumble dryer, dish washer. Appliances hard wired in - safer. 40A RCBO.
5. 6mm cooker cable to the oven and induction hob - no need to be on separate circuits. Both hard wired in. 40A RCBO.
So, four circuits. One AFDD and three RCBOs. 1.00mm and 1.5mm cable used. Cheap and safe.
The same could be for an average British semi. Maybe with two lighting circuits - but two are not required. This gives five circuits. Installation costs are then cut right down.
Q2 proves to some extent that this is trolling when did legal find it's way into an electrical installation when we all work to the recommendations of a non statutory documentNuisance tripping? Where? How?
Overloading? Where?
Q1? Is it safe? Yes.
Q2? Is it legal? Yes.
Q3? Does it protect against arcing on sockets? Yes.
Q4? Does it give full RCD protection? Yes.
Q5? Does full overload protection? Yes.
Q5? Does it give full fault protection? Yes.
Many years ago most installations only had 3 or 4 circuits so your argument isn't necessarily correct in general more circuits are used these days to minimise the inconvience of tripped circuit taking out a large section of the installationYou may not see an argument for it, and more will be on your side because of: we have alwasy done it this way. My point is that as AFDDs are expensive and mandatory with copper cable prices rising as world copper prices rise, these sorts of installations may be coming soon, and be quite common.
So where do you get that the British are famous for oversizing cable from and who is it thinks this could it be YOU when maybe it is done from a more cautious point of view at the design stage, electrical installations are always changing and evolving especially within the kitchen with hobs and ovens of various loads from 2Kw upto more than 10Kw a few extra pounds now can potentially save some money in the future when an appliance is changedAs a side issue, the British are famous for over-sizing cable. 6mm to a hob when 4mm will do it. 1.5mm for lighting when 1.00mm can do it, 2.5 from an FCU to an appliance when 1.5mm can do it, etc.
