H
Hereforhelp
Hi all,
I’ve been asked to run a cable for a 3 phase DC motor. Not having much experience with motors would you work out cable sizing the same?
In the picture attached are the details I have received.
Any help would be great
As far as I know, there is no such thing as a 3 phase dc motor.
from the nameplate, i would guess that it is a servomotor.
there are special types of cables used to connect them to the servo drive.
Can someone tell why a DC motor would have a frequency of 50Hz on the rating plate which clearly shows in the OP's picture
I assume that is a very large motor with a nominal weight of just under 5.6 Tonnes
I suspect either soneone is winding the OP up, or he is winding us up.
Until he comes back we won't know though.
4mm2 cable method C , min depending on the length of the circuit. Don't forget volt drop & startup current for choice of mcb. Please do your own check calculation to clarify the above.
Hereforhelp,
davesparks,
