- Jul 15, 2016
- 23,301
- 1
- 29,151
- 315,788
- United Kingdom
- Electrical Engineer (Qualified)
Yep, just a little downward pressure before sliding out.There is a little nobble on it just pop it out with a flat screwdriver.
What's wrong?.....looks like there's been an NIC domestic installer involved, all is rosy.Manager says we had a pir on one of the cottages and Sparky man says that the sub main hasn't an isolator, can you sort one out.
It's fed from here, another cottage next door.
A pair of 16mm t&e feeds 2 cottages from the henleys.
urmmmm i think it needs a bit more than an isolator.
You’ll never be short of a Henley block after sorting that lot.Manager says we had a pir on one of the cottages and Sparky man says that the sub main hasn't an isolator, can you sort one out.
I have a box of about 60 removed over the last few years, along with about the same amount of junction boxes.You’ll never be short of a Henley block after sorting that lot.
Del would be in his oils in a place like this, coolIts fine it has the NIC seal of approval sticker on it...
Just a few screws in the bottom left corner to remove, as it doesn't look professional to leave them laying there.What's wrong?.....looks like there's been an NIC domestic installer involved, all is rosy.
He would Meggering everything within an inch of its life , Sucking his teeth, splitting the rings up , making some beautiful 25amp radials to get the homeowner out of troubleDel would be in his oils in a place like this, cool
That is how I expect every bg board to lookRemember those pictures where you have to spot the dangers, and everything's a danger?
As BG board installs go I actually thought it looked quite neatThat is how I expect every bg board to look
I agree and of course it's much better without the earth sleeving, stays cooler and nice shiny copper always looks nice.As BG board installs go I actually thought it looked quite neat
Oh what fun can be had with a pair of old boots and some black spray paint
It is possible to make consumer units out of the same material as the meter, however, it would likely depend on the specific material in question and the requirements for the consumer unit.
In general, consumer units (also known as electrical distribution boards) must meet certain safety and performance standards, such as those established by national and international electrical codes. The material used to manufacture a consumer unit must meet these standards and be able to withstand the electrical and environmental conditions it will be exposed to.
Yes it was…. Like why don’t we make aeroplanes out of the same stuff as the Black Box.I think it was a tongue in cheek comment.
All the work of one person?Seen this a few times recently. One of which had an OZEV audit and wasn’t picked up.
Don’t think so unless they’re sub contracted.All the work of one person?
