Ahh photo too large for the server to process.
I screenshot a phone photo, then crop out the extra screen… reduces the picture enough to be under the size limit.
Or crop the original.??
Was it the wasps or the mice that eat the phone cable?
Thanks guys.
Reactions: nicebutdim and DPG
Mural wiring... looks legit
Wait, what?
A call to WPD National Grid, and 2 hours later...
Can't really blame the workmanship or materials in this case. On the end of the 4-way extension lead was a small heater, a chest freezer, a fridge and yes, you've guessed it, a tumble dryer. I'm surprised it lasted as long as it did.
Probably a lathe and plaster wall. I've used every screw hole available on many occasions, plus a bit of adhesive on the back.
Exactly this - only two of them were actually doing anything. This house has a mixture of L+P, L+P with plasterboard on top, and in one case L+P ceiling with OSB board and then ceiling-board which made fishing delightful fun...
I absolutely hate lath & plaster.
Nothing to do with my parents house, my flat, and my sister's house all having the damn stuff and needing odd jobs done over the past few decades :(
Just rewired a house in which old tongue & groove timber was directly behind plasterboard on ceilings and stud walls. An absolute pleasure to work with.
Reactions: DPG and timhoward
Reactions: timhoward and DPG
  • Funny
Reactions: DPG and nicebutdim
Reactions: Dave OCD
Call out today as a light switch kept tripping the MCB of the circuit. So after finishing another job I called in on my way home.
I'm surmising that some hamfisted clod has knocked a nail or screw through the cable and it's failed over time. 2 of the 3 conductors had a short when IR testing.
Replaced the 2gang switch then had to go old school to pull a new piece of 3C&E through to make a temp fix. Told them they need to find where the leak is in the property and stop that before I do anything else. The back box has almost disintegrated and the wall and ceiling are damp to touch. So will be back to fit new capping and back box once they have sorted that out.
View attachment 107162View attachment 107160View attachment 107159View attachment 107161
And maybe a MF enclosure, you do get some lovely work though :)
The MF enclosure is what I put in when I pulled the new bit of cable through.
Reactions: Cagethethird
The wago light isn't mf ?
Ah, I misinterpreted what you meant. Yes I know it's not a permanent solution. They may have to replace the ceiling plasterboard so I am waiting to see what happens as I may just run a new complete section of cable.
With the amount of water/damp they could do with a gel box :)
  • Funny
8K
Darkwood,
mainline,
