As I college student.
I'm still just experimenting with equipment etc.
I have the megger bm223 without the test leads
Can anyone recommend some cheap Test Leads for this. I'm only using these for my home study. Not professional work or anything.
Thanks.
I think so mate. I'm just a college student, so not that much knweldge yet. So I believe it is. But not sure about the max voltage etcAre they not just standard 4 mm test leads ?
I believe it’s an insulation resistance meter so it’s max voltage may well be 1000 volts , this however is most likely limited to 1 milliamp , if there is any chance you will be using this in a work environment you should use GS 38 test leads
The originals would have had straight plugs but these will do the job.
HandyMAN TEK112 Unfused Test Lead Set
HandyMAN TEK112 Unfused Test Lead Set The HandyMAN TEK112 Unfused Test Lead Set contains two unfused multifunction test leads with 90º probes, removable crocodile clips and 4mm red/black plugs. The leads measure 1.5m in length and are suitable for insulation testing. These leads are double...www.test-meter.co.uk
Hi mate
Thanks for that.
Irs say these are suitable for Insulation Resistance testing. Would it be also good for continuity testing ?
And are the GS38 compliant or not? At this stage I'm not fussed about that.
You could always try bidding for these in a couple of days time, but it seems someone else is interested unfortunately!
Megger 1002-015B 2 Wire Fused Test Lead Set | eBay
Megger 1002-015B 2 Wire Fused Test Lead Set.www.ebay.co.uk
Which do you recommend ?And bear in mind the difference between fused and unused test leads. It can make a difference, depending on what you are testing.
But always an advantage when someone tries to measure current by placing the leads across positive and negative of a supply!
It doesn't need fused leads, most insulation resistance and continuity testers are normally internally fused for "mishaps".
The ones in my link aren't. Never used an IR/cont tester with fused leads.Indeed. And most multimeters also are fused on their current ranges.
Non-fused leads also avoid any inconsistensy on low ohm ranges when the contacts starting getting aged/tarnished.
I only mentioned it because the ones in the link are fused.
