Dec 21, 2022
212
Yorkshire
Trainee Electrician
As I college student.
I'm still just experimenting with equipment etc.
I have the megger bm223 without the test leads
Can anyone recommend some cheap Test Leads for this. I'm only using these for my home study. Not professional work or anything.
Thanks.
Thanks.
Anyone ?
Are they not just standard 4 mm test leads ?
I think so mate. I'm just a college student, so not that much knweldge yet. So I believe it is. But not sure about the max voltage etc
I believe it’s an insulation resistance meter so it’s max voltage may well be 1000 volts , this however is most likely limited to 1 milliamp , if there is any chance you will be using this in a work environment you should use GS 38 test leads
Reactions: shocksl
The originals would have had straight plugs but these will do the job.
Hi mate I believe it is a insulation resistance and continuity tester. If I'm not mistaken.
At the moment I'm not doing any work as I'm just in Yr 1 college. .. won't be in work for atleast a couple of years.
Can you please send me a link to 1 or 2 reasonabley priced ones that I can use to practice at home with. Don't need GS38 atm. I will need crock leeds too.
Thanks mate
Hi mate
Thanks for that.
Irs say these are suitable for Insulation Resistance testing. Would it be also good for continuity testing ?
And are the GS38 compliant or not? At this stage I'm not fussed about that.
Hi mate
Thanks for that.
Absolutely fine for continuity testing yes. And they meet the CAT II/III requirements for connecting to mains voltages, so all good!
Reactions: shocksl
You could always try bidding for these in a couple of days time, but it seems someone else is interested unfortunately!
And bear in mind the difference between fused and unused test leads. It can make a difference, depending on what you are testing.
But always an advantage when someone tries to measure current by placing the leads across positive and negative of a supply!
Which do you recommend ?
I'm needing it for college dead testing ?
It doesn't need fused leads, most insulation resistance and continuity testers are normally internally fused for "mishaps".
Reactions: DPG and nicebutdim
Indeed. And most multimeters also are fused on their current ranges.
Non-fused leads also avoid any inconsistensy on low ohm ranges when the contacts starting getting aged/tarnished.
I only mentioned it because the ones in the link are fused.
Reactions: nicebutdim
The ones in my link aren't. Never used an IR/cont tester with fused leads.
Yeah sorry, the later link. Not yours. Give me a break Westy - it's nearly the weekend :)
And I only posted that link because they are Megger labelled "2 wire test lead set - insulation testers" including, as it turns out, for the BM series 🤪
I used to use that exact model the plugs were straight and not angled, definitely not fused.
Well the photo of the back of the Megger packet says "Fused test lead set" so the seller is not mis-describing them!
Yorkshire
Trainee Electrician
Which test leads ? Meter without leads
Electrical Tools and Products
shocksl,
Avo Mk8,
