A few mechanical failures but not electrical, why do you ask?Sorry for being silly, but wondering if anyone has come across any failures of GU10 fittings (the fitting itself, not the bulb)?
Had failures of the twist on GU10 connector and wires on occasions, but only with 50W incandescent halogen lamps, presumably due to heat. No fitting failures with GU10 replacement LED lamps.
The lamps I kept on the shelf and used with fittings I installed were dichroic, but I never really took much notice when fault finding in customers' houses.That's interesting. For those halogen bulbs did they have aluminum or dichroic reflectors?
Any GU10 can with a 50W lamp, that had been installed for a while would have seriously cooked the plasterboard around it, making it difficult to remove without ceiling damage. Best way was to pull one side of the fitting down a few mm, then flip the fixing spring off of one of its pegs, then pull down the other side and repeat. Risked never seeing the springs again, but that's preferable to a ragged hole.
Any halogen lamp, and several other types, have the capacity to explode on element failure, which is why a GU10 lamps element is double sealed, and other forms such as linear floodlight bulbs must be behind safety glass (although open-rated hardened glass lamps were an option)Thanks - this has been really useful
Not a fan of halogen lamps anymore - not to mention the power consumption or cooking up the plasterboard, mains halogen lamps could arc and explode badly in the wrong circumstances...
I've never come across a failed GU10 connector, MR16's became unreliable but then they had 20x the current @ 4 amps each to deal with in addition to 300 odd degree heat.
Bulb elements can collapse and short circuit (back when stuff was made properly filament bulbs incorporated fuses so they didn't knock out the lighting circuit) but in halogens shattering it's more the hot ruptured element hits the glass and the thermal shock is too much, easier to see on this linear, the two blobs are fragments of element melted its way through the glass which has re-set instead of shatteringJust curious, have you ever come across any LV halogen exploding? Since they work on a far lower voltage, would they be less likely to arc than mains halogen? I know the quartz capsule could explode if heated non-uniformly (especially if in contact with hand grease), but might arcing be another cause for explosion, I guess? (I might be wrong...)
And speaking of the difference in current, is it that LV halogen normally runs hotter than mains halogen of the same wattage?
That's really interesting and informativeBulb elements can collapse and short circuit (back when stuff was made properly filament bulbs incorporated fuses so they didn't knock out the lighting circuit) but in halogens shattering it's more the hot ruptured element hits the glass and the thermal shock is too much, easier to see on this linear, the two blobs are fragments of element melted its way through the glass which has re-set instead of shattering
As for current, remember P=IV, so drop the voltage by x20 and for a given power the current has to increase. I=P/V, 50/12, 4.16 amps.
I dont know if LV officially runs hotter - they do seem a little hotter and are measurably brighter than GU10's for a given wattage though
GU5.3/4 IS 12v, unless china was doing weird stuff, there were 240v reflector bulbs (R80, etc) normally ES/SES before that. GU10 arrived in the late 90's to replace the need for transformers but the 12v's were still better than GU10 in terms of light quality... then LED kind of did away with everything.That's really interesting and informative
Back when I was little (in China, late 1990s), mains halogen reflector bulbs (GU5.3 MR16 / GU4 MR11) were popular when it came to spotlights, which then were superseded by 12V ones from 2000s onwards before being eventuality substituted by LEDs.
Wonder if mains or LV halogen came earlier in the UK (should you ever know a bit of history)?
Unfortunately yes it IS just this weird. Even today those poor old joe remain in those older late 90s flats / houses so there's still a niche market for these. Look onto Taobao (Chinese equivalent for ebay) and you'll find: (1) 220V GU4 / GU5.3 reflectors still widely available from domestic brands like FSL, and (2) occasional negative reviews on 12V bi-pin reflectors from clients who inadvertently hooked them onto mains but didn't realize what was wrong.GU5.3/4 IS 12v, unless china was doing weird stuff
Did you mean like tp24 downlights?Ask me how many of those rotten CFL 's that were made with long necks so you couldn't put standard halogens in them
