This is a DIY project. I am not an electrician.
I have two LiFePO4 batteries to power the equipment on on a 12 foot plastic jon boat. One battery is 100AH and one is 10AH. The primary use of the 100AH battery is to run the trolling motor. The primary use of the 10AH battery is to run accessories, like a fish finder and lights. The primary reason for the two batteries being on separate circuits is so the trolling motor doesn't introduce electrical noise that could degrade the performance of the fish finder.
For backup purposes, I would like either battery to be able to power both the trolling motor and accessories if ever needed. For this, I'm thinking of using a transfer switch, then a couple of diodes to prevent the battery with a greater charge from dumping into the other battery.
Switch Positions: Normally, the manual transfer switch would be in Position #0, so each battery is on a separate circuit. If the 100AH battery runs out, then moving the switch to Position #2 would allow the 10AH battery to power both the accessories and the trolling motor. If the 10AH battery runs out, then moving the switch to Position #1 would allow the 100AH battery to power both the trolling motor and the accessories.
Will the schematic I've attached work? Is there a better way to achieve my goal?
Thanks,
Andrew
Quick Question: Assuming the schematic is correct, I plan on removing both batteries from the boat when it's not in use, so I don't expect I'll need to worry about isolating the batteries for charging. But it seems to me (if my schematic is correct) that with the diodes the batteries will be isolated regardless of the transfer switch position. So, I could charge one battery, then the other, while they are in the boat. Is this correct?
TL;DR
For powering a trolling motor with one battery and boat accessories from a second battery, is the attached schematic the best way to allow either of two batteries to serve as a backup for the other?
Thanks,
Andrew
What sort of current is being drawn ? You may need rather large diodes, also you will get voltage drop across them.
Maybe easier to use a crossover switch or relays.
For the trolling motor it will be 35 amps max at 12vdc. The accessories will be less than 10 amps total.
I was wondering how much of a voltage drop would occur across the diodes, but I couldn't find the information. I was crossing my fingers it wouldn't be too much.
Anyway, I just canceled the order for the diodes. It was better to do it before the order was processed. In their place, I just ordered a disconnect switch for each battery. I need something that will surface mount and I couldn't find a crossover that would work for where it needs to be placed.
Thanks for the alert. Please let me know if you notice anything else that it would be better for me to do.
The circuit could be simpler, and diodes not required, if you can common the -ve terminals of the batteries and use it as a common feed. Is that possible, or maybe it's already the case?
Have you identified a marine low voltage DC switch that will perform the function you illustrate, as I haven't 🤔
PS Schottky diode (which I think it would be) voltage drop max 0.5V
...you can common the -ve terminals...
Doh! I didn't think of that. That indeed makes it simpler for both the schematic and the actual wiring.
Have you identified a marine low voltage DC switch that will perform the function you illustrate...
No. However, I'm okay with a non-marine switch. The area where the switch is located is protected from water, spray and otherwise. Also, I didn't show it in the schematic but the 100AH battery has a breaker, all the accessories are all fused, as is the trolling motor. I'm thinking this should protect me from the consequences of any shorts. Am I correct?
I'm glad I cancelled the diodes. 0.5V is more than I care to loose. The trolling motor is the sole power source for driving the boat. No outboard. I'll be using an aftermarket propeller to increase the speed of the boat. I'd have to test it after installation, which I'm not going to do, but I suspect 0.5V would negate the gain I get from the better prop.
Thanks again,
Andrew
It would be desirable to get a switch specifically rated for low voltage high current DC, as marine products typically are, rather than a switch designed for 240V AC, because I believe the contacts and action are designed differently. However if you are always going to be operating the switch 'off load', that may not matter!
Yes if you're saying the 100Ah battery has a circuit breaker is series to protect the wiring, that seems fine.
Below a sketch (if I dare call it that!) of how you might wire it with a two pole three position centre off switch, assuming making the battery -ve's common is valid, and won't adversely affect EM interference from motor to fish finder! You might find a EM filter would help that.
Otherwise, if you can't common the -ve's, put the same switch arrangement in the -ve side of the batteries as well. You would need a 4 pole version of the switch, but that shouldn't be a problem to find.
PS, Taking 35A from a 10Ah LiFePO4 battery won't do it much good long term, but presumably this is more an 'emergency' provision than for regular use 🤔
...if you can't common the -ve's, put the same switch arrangement in the -ve side of the batteries as well. You would need a 4 pole version of the switch, but that shouldn't be a problem to find.
So, I've perused the Garmin (fish finder) material and users' comments. A common -ve is not recommended. Am I back to my original drawing for the switch assignments (plus using a disconnect switch on each battery to prevent the good battery from charging the dead battery when in Position 2)? Will that work as well as a 4 pole switch - which I'm not understanding. It seems to me that I'd need a 2 pole 4 position switch, where:
• Position 1: 100AH to motor | 10AH to accessories
• Position 0: nothing
• Position 2: 100AH to motor and accessories
• Position 3: 10AH to motor and accessories
What am I missing with being able to use a 4 pole switch?
Again, thank you for all the help with understanding and implementing this.
So, I've perused the Garmin (fish finder) material and users' comments. A common -ve is not recommended. Am I back to my original drawing for the switch assignments?
Not quite. I'm suggesting that the battery terminals go only to the switch, and you arrange the contacts to take the appropriate battery polarity to the appropriate load. You won't need diodes if you do it this way.
I've drawn a two pole 3 position switch. Since it seems you need to switch the -ve's as well, you would need a 4 pole 3 position switch (as I've drawn but with switches added for the -ve terminals as well)
You can implement this with a 4 pole 2 way centre off switch, or a centre off cam switch with 8 sets of contacts. Are you happy to work out the logic of this?
As long as you route all battery connections only to the switch, and arrange that to feed each appropriate load wire for the switch position, you'll be fine.
Sorry, I'm just not getting it. Would you please send me pictures or links to the two types of switches you are describing? I'm not visualizing how it can be done with just 8 sets of contacts and the battery connections only going to the switch.
Thanks,
Andrew
Thanks,
Andrew
Ok. These were my thoughts. Need checking through.
And to add an edit here - I had not appreciated your desire for different permutations of whar powers what. The following explanation doesn't do that.
But I think a switch with more positions might - I need to give it more thought!!
The first type of switch that came to mind was 4 pole centre off double throw, this sort of thing, but this is not high enough current:
Each battery would be wired to a pair of contacts in the middle, and the motor and accessories wired to the outer terminals, as illustrated in my diagram.
The more likely choice would be a rotary cam switch, with sets of changeover contacts, such as this:
Say 100Ah battery -ve to 2&4 batt +ve to 6&8,
10Ah battery -ve to 10&12, +ve to 14&16
Then for 'normal' operation, motor +ve to 1, motor -ve to 5, and accessories +ve to 9 and -ve to 13
And for 'reversed' operation, accessories +ve to 3, acc -ve to 7, and motor +ve to 11, -ve to 15
If the links for UK products don't work for you, please let me know.
I've been trying unsuccessfully to find a marine equivalent of the above changeover switch, but so far no luck. I had been discounting the use of relays because that wouldn't be so efficient!
Sorry when I first read the above post I missed these permutations you want to achieve.
I didn't spot that from your original diagram, and I had thought all you wanted to be able to do was swap the batteries over. As a result the things I've proposed don't meet these requirements!
😀 I tried to send an update to my post above, with the picture I attached here, but it appears it didn't post. It's showing the 16 positions like you have shown. I used this same switch (link below) for a project in our camper (that we have since sold). It worked like a charm. It's not marine grade, but it will be in a protected location. And like I mentioned before, there is a DC breaker on the 100AH battery, plus everything is fused. I'm thinking the worst case is the switch fails/shorts and I'd have to drag the battery up to the trolling motor and connect it manually.
Do you think this switch will work?
I think I have to admit defeat at this point. I hadn't read the spec properly!!
As the permutations go up, so the switch positions go up, and, at least for cam switches, the current capability of the whole switch assembly goes down (heating effect), the price of the switch goes up, and this solution seems to become impractical.
I haven't been able to identify a product that would cover the 4 position scenario with my approach!
Sorry 🫣
...the current capability of the whole switch assembly goes down (heating effect), the price of the switch goes up, and this solution seems to become impractical.
It surprises me that a switch rated for 27,720 watts (63 amps x 440 volts) AC can't handle 540 watts (45 amps x 12 volts) DC. The wiring seems straightforward. But I don't know what I don't know.
If you can think of something, please let me know.
Thanks again,
Andrew
Thanks again,
Andrew
This would do the battery changeover, you could use a pair of relays instead if dpdt aren't easy to get.
Same circuit again for whatever battery you want to run accessories.
You can hide the relays away and have a pair of small water-resistant switches remote from them.
I didn't mean to scare you away from ac switches! I think the 'closed contact' part of their lives should be fine. It's just that I understood what happens when the switch contacts open and close is a bit different with ac and dc current. As you have already suggested, when operating your switch it may not be loaded, or at least not very much. And it's not as if it will have to withstand many thousands of operations in the boat! I suspect an AC switch will work for you fine, so please ignore the comment.
Re your post #12, I'm still cogitating how you connect say the "motor + Accessories +ve" combination without connecting them together. Was this done including a diode somewhere?
If you draw where all the wires go to on the right side of the switch, you end up connecting circuits together that need to be separate for position 1 of the switch to work?
Mainline's post of having a switch for each battery sounds interesting!
Switches intended for DC operate their contacts quickly and to a larger separation gap than AC switches to avoid continuous arcs.
I'm old enough to remember light switches being sold that were designed for AC/DC or AC only. The AC/DC ones used an underslung 'over centre' mechanism, where the switch operates suddenly with an audible 'clang', however slowly the rocker is moved, while the AC only used a cam mechanism, similar to that in current switches.
that works
But it's the additional combinations of both motor and accessories from either one or the other battery that are described in post #1 that are more difficult to achieve, though I think relays might be the answer to that as well.
I've failed to come up with a purely switched solution that doesn't require diodes otherwise!
Thank you everyone for the input.
I'm not sure about using relays. I haven't used one in decades and I'd need more schooling to know just what to get.
I'd like to avoid using diodes. I suspect the voltage drop will negate the extra speed I will gain by purchasing an after-market propeller. Since the trolling motor is the only propulsion for the small boat, I want as much speed as I can get. Any voltage drop is a step in the wrong direction.
Please take a look at the attached. I'm thinking it will work, but I'd like your eyes.
Thoughts?
that works
Another relay using the same circuit as described could be used to switch the accessory supply to either battery.
There are plenty of high current relays around and would probably be cheaper than the cost of the switches.
that works
If it works safely then that's what I need to know, should I choose to go that route. I already have the switch. It's left over from my camper. That said, using relays would certainly be more attractive and elegant of a solution - and I like elegant. So if I'm going to take the time and trouble to do this then I'll mostly likely go with the relay solution.
But I just got the boat. Right now, I'm only planning and won't immediately be implementing either option. For the moment, I'm going to run the trolling motor directly through the breaker from the 100AH battery. I'll run the accessories directly through the fuses and 10AH battery. Should one battery die then just I'll manually move the leads to the remaining battery. It would be kind of a pain, but doable. If after using the boat for awhile I find out that I do commonly run one of the batteries dry (most likely the accessories battery) then I'll be doing what we've discussed (most likely with relays).
Thanks everyone. I'm always learning something new here and greatly appreciate the help and the time you have spent. If/when the time comes, I'll post back with my chosen relays and remote switches for your review - to assure they are appropriate. More than even convenience; shock, fire, and problem avoidance is my goal here.
Thanks again,
Andrew
It's unnecessary to switch the negatives, whatever circuit is used. If you have double pole switches it would be preferable to connect both poles in parallel to share the current between them.
Can't we do this in a much smpler way?
Totally independant switches for the trolling motor and the accessories
That's the same as the relay circuit #15 And #21
1) I had difficulty viewing the pic in #15 is on this older laptop (another pc does look better). Indeed it is similar,
2) I have simply offered what I believe is the simplest solution to TimeOutside's request for assistance.
I haven't attempted to look for a source but I believe DC rated isolator/changeover switches of the MCB fromat are used within PV battery systems.
Garmin not "recommending" a common -ve is not the same as saying that it won't work.
Doubtless they are trying to avoid the possibility of noise being induced in the wire and this can be a real thing but they are probably being over-cautious. In a big boat with lots of heavy duty stuff going on then yes, but your proposed setup is close to as minimal as it gets.
Okay, so you have a (low'ish power) motor and with that comes the possibility of commutator noise from the brushes but that's about it. Is the motor a brushless design - many are these days?
Keep the shared -ve short and fat.
How many hours of trolling are you expecting to engage in on each trip? Based on your suggested max load currents I personally would be looking at a larger battery than 100Ah. Similarly for your accessories - the battery spec looks a little on the low side TBH. Do you have previous experience of the run times that you can actually achieve with these battery sizes? If so then I demure to your lived experience.
What currents are typically drawn rather than the max's? The answer to this one can have a big impact on the achievable runtime from your batteries.
I am not convinced by your suggestion that you will not need marine grade switch gear. IMV, anything on a boat should be treated as requiring marine grade kit. If you operate on saltwater then you would have to be mad not to fit marine grade stuff. Even a fresh water environment in an exposed cab (whether in a small cupboard or not) is going to see rampant corrosion. In saltwater I would not be considering chancing it without marine grade kit at all.
Take a look a this:
There's lots of other useful looking kit to be had on that site as well.
If it were my boat and I needed to rely on a motor getting me back to shore I would be looking at a third battery reserved just for this purpose and this purpose alone.
Take a look a this:
It’s a 12ft Jon boat, so I doubt he will be in the sea with it.
He could probably easily paddle back.
I'm fond of hiring such boats in the Fowey estuary.
Saltwater and strong currents.
locations such as this abound all over the UK.
Very interesting, but not really related to the OP as he's in Missouri and the last I heard it was landlocked.
The motor will undoubtedly be a brushless one driven by PWM The rapid changes in voltage and current associated with PWM can introduce noise onto the cables, potentially causing interference with other electronic components or even damaging sensitive circuits.
Hey, I'm just trying to help.
Not really quite sure why you have decided to take quite such an issue with my messages.
I'm glad you are so sure what the motor will "undoubtedly" be, BTW. Me, I try not to assume if I can avoid it.
As an electronics design engineer who has designed high speed computers as well as a variety of stuff for use in the inhospitable environment of various military vehicles (on land, sea, and in the air) in the past I am also fully aware of the implications of induced noise in cables (though I guess you are struggling to believe that given the stance you appear to have decided to take).
As I said, I would regard anything electrical that is to be left in place on a boat as a distinct corrosion risk - including one on freshwater.
If his motor is not PWM driven then he should add a Pwm module to it.
You didnt mention anything about the possibility of Pwm causing problems in fact you said :
EalingBadger:
"the possibility of commutator noise from the brushes but that's about it"
Nobody has said any different so i dont know why you feel the need to repeat it.
You proposed that the OP fit 2 larger batteries along with a 3rd for spare in his plastic 12ft boat.
£150 worth of bulky switches and ignore the recommendation of the manufacturer about parallelling the -N even though you know that Pwm can cause damage ?.
A pair of relays in an enclosure with 2 small waterproof switches to me seems like a no-brainer.
It would also be very simple to make them switch over automatically if wanted.
EalingBadger:
Whatever, mate.
You just seem to want to be argumentative for the sake of it.
I can’t be arsed to address your points with counter-arguments. It's not worth the effort.
I will just say this though and that is that you appear to be under the impression that PWM WILL cause damage. Whether it will or not is very much a function of the circuit configuration and the powers involved and is very far from the racing certainty that you seem to want to imply in this simple low powered scenario. It's all about the impedances (as I'm sure you know).
It's not all about Impedance at all.
Impedance is the property of a circuit, not the signal, unless there are diodes etc in the circuit if there are then the circuit could change depending on the signal.
Therefore, damage can occur, note I don't say WILL occur.
Impedance is ALL to do with the signal
Impedance is primarily concerned with how a circuit, or component within a circuit, responds to a signal, particularly an alternating current (AC) signal. It's the opposition to the flow of current, considering both resistance and the reactive effects of inductors and capacitors.
Yes that just about sums it up, except that without a signal there is no impedance.
The impedance /resistance /inductance etc of a circuit is still there it doesn’t magically disappear so how you can make a statement that’s it’s “All about the signal” is beyond me.
You don't need a signal to have impedance. Impedance is a property of a circuit or component .
Missouri, USA
United States of America
Jon Boat Wiring: Diodes & Transfer Switch
DIY Electrical Advice
TimeOutside,
mainline,
