I assume this Class I light has no cpc.
I didn't get around to looking at the wiring for the light... There was definitely a CPC in the switch, but it had something like 50V to line, so likely no continuity of CPC.
She's not going to get any of the work done though. She just can't face any disruption whilst her husband is ill (very bad dementia).
As a matter of interest. Would you guys have changed the bathroom light for a class 2 one, and fitted a new switch? even though there is a neutral to earth fault on the circuit, no working earth and no RCD?
It's the old argument of the installation would have been in a slightly less unsafe condition by me actually doing the work, even though I am supposed to fix the faults first (which she wouldn't agree to).
45A.
So was this Class I light earthed?
Impossible to say, as I didn't remove the light.
All I can say is that the CPC was not working in the switch. The cable could have gone to a junction box which had a working earth and then to the light, so the light may have been earthed (but probably wasn't).
Under the circumstances, yes I would.
sometimes, you are between a rock and a hard place.
fit a light of any type and you reduce the risk of tripping over in the dark
but if there was a fault and they were touching the light, you have increased the risk.
cant win situation. just do what you think is morally correct at the time and be happy with it.
Sometimes you have to choose the lesser of two evils. Safety is not always black and white.
Wouldn't stay the right way for me, so snipped it and it worked.
