I managed to find a flame-retardant filament - Kexcelled K6 PLA FR
Are you sure PLA is adequate?
The glass transition temperature of PLA is about 55°C. I'm sure I read somewhere that the temp the socket or backbox material it tested at is about 80°C. That is why ABS would be better.
Edit:
I've just had a look on Google and apparently the standard is BS EN60670-1 Clause 18 & and the temperature is 75°C
"In that specific clause, the text explicitly states that parts of insulating material not necessary to retain current-carrying parts in position must undergo a ball pressure test inside a heating cabinet at (75 ± 2) °C."
Normal PLA will fail this.
Edit:
That’s a fair point. The Kexcelled K6 PLA-FR has a quoted glass-transition temperature of 60°C, and from what I’ve found, the relevant heat-resistance testing appears to be 70°C (maybe 75°C if you've got access to a more recent standards version than me?).
So although the flame-retardant PLA is a clear improvement over standard PLA, it still doesn’t give enough temperature margin for me to say the finished part would definitely satisfy the relevant standard (or give an insurer one less excuse to wriggle out of paying up).
I’m now looking into flame-retardant ASA and ABS as well. The problem is that these filaments are quite difficult to source, and the colour options are very limited. I might be able to find both black and white if I’m lucky, but likely no more than that. :confused:
Cheers,
Luke
What I put was just from what Google stated to me. I did not verify it as I don't have the spec. If it is 70°C then that is better for you.
Yeah, from what I was when I looked into this, the choice of colours is very limited...
Afternoon all,
A quick update on the spacer plates after a bit more experimenting with materials.
Following the discussion above about PLA-FR and heat resistance, I’ve been trying some higher-temperature flame-retardant filaments. I’ve now settled on SUNLU FR-ABS for all of the spacers going forward.
According to SUNLU, the material is:
  • UL94 V-0 flame-retardant
  • Self-extinguishing within seconds
  • Impact resistance up to 14 kJ/m²
  • Heat resistance quoted at up to 86.5°C
  • Designed to have relatively low warping and good layer adhesion for an ABS material
The main reason for changing is the temperature margin. The Kexcelled PLA-FR I was using previously has a quoted glass-transition temperature of around 60°C, which was a bit under the sort of heat-resistance requirements (70/75°C) we were discussing earlier. The FR-ABS gives some comfortable temperature headroom while still retaining the flame-retardant properties I wanted.
It has taken a bit of experimenting (and a new ventilation system) to get it printing nicely, but my printers seem quite happy with it and I’m pleased with the finished surface.
The downside, as expected, is colour choice. Flame-retardant ABS is nowhere near as widely available as ordinary filaments, so I’m now limited to black and natural white - the latter being more of a slightly warm/off-white than a bright white.
Thanks again to everyone who raised the temperature issue earlier - it sent me down a useful rabbit hole! 😄
If there's anything else you'd like to see on the website, or in the Build My Spacer tool then please let me know.
Cheers,
Luke
Thanks for the update. ABS does give off a bit of a stink and is not the best to be beathing in. We don't use it much so just open the window.
I'm curious, what printer do you have & what is your "ventilation system"?
Most of my printers are Bambu P1S's. I've also got a Qidi Plus4 for larger items, and a Snapmaker U1 for multicolour prints, although I've avoided doing too much multicolour up to now because of all the time-consuming filament swaps.
For ventilation, I've got ducting connected to the printer enclosures using some adaptors I printed, with an inline fan keeping them under constant negative pressure so fumes are drawn out rather than escaping into the room. The ducting then vents through the window, which is sealed using the same sort of kit you'd use for a portable air conditioner.
It's not the prettiest setup, but it seems to work well - I don't get any noticeable ABS smell in the room. I've also got a HEPA and activated-carbon air purifier running as a bit of extra backup for any escapees!🤞
We have X1C's and a Qidi Plus 4. The Snapmaker U1 is quick for colour changing... A lot quicker than your P1S's and uses a lot less filament while doing it. The Snapmaker U1 will be the next printer we get, unless something else that is just as good comes along.
You probably already know this but, you only need very little negative pressure on the connection to your printers as too much will just take all the heat from the chamber, which will make printing ABS more of a pain.
Nice! The Snapmaker managed the little dragon it came preloaded with very well, but in other prints I've struggled to get the quality as high as with my trusty Bambu's... I'll probably save it for when it's really needed.
If you want true multicolour then the HeyGears G1X looks insane, but it also has a price tag to go with it! :sweatsmile:
That's a shame. I've seen people do really nice prints with them. Maybe try calibrating the filament settings again.
That's a really nice printer but at the mo, not worth the price. If I had 5 grand spare it would go on something else..
Bambu
That does look like a good one! I think the Snapmaker changes colours quicker, but I've always been impressed with Bambu for quality, so will likely stick with them going forward. :)
Snapmaker changes colour a lot quicker than the H2C (if you are doing more than 2 colours)
Bambu Lab do good printers but I don't like their ethos. IMO banning Orca Slicer and other 3rd party items was a mistake. Also blaming the customers for when they had problems with the A1 was not good.
I have stopped updating the firmware on mine as I want to use Orca Slicer. It's highly unlikely I will be buying another Bambu printer again. Up to now, my next printer will be the Snapmaker.
Hi all,
I run a small UK business making custom spacer plates for plug sockets, light switches and other faceplates. They’re mainly for jobs where the socket/switch has ended up recessed after tiling, plastering, panelling, etc. or where there isn’t quite enough room behind the faceplate for the wiring.
I've now moved them onto a dedicated site:
There’s a simple “Build My Spacer” tool where you can choose:
  • single or double gang, or larger gang sizes​
  • width and height​
  • depth​
  • colour​
  • corner radius​
  • fixing lugs or no lugs​
  • quantity, with multi-buy discounts​
They’re intended as a neat way to bring the faceplate forward and get a better fit than packing pieces or standard off-the-shelf spacers.
As a small thank you to the forum, code FORUM-LOVE gives free UK delivery at checkout.
View attachment 125020 View attachment 125021 View attachment 125022
I’m still improving the site and product range, so I’d genuinely welcome feedback from electricians on what would make them more useful on real jobs - common dimensions, colours, fixing options, awkward faceplates, brand-specific details, etc.
If anyone wants a look, the site is:
https://socketspacers.com
Cheers,
Luke
Great bits of kit and needed in some install, but customers want the box dug out to make it fit flush most of the time
Yeah, definitely - if the customer wants the box dug out and made flush, that’s the neatest option. The spacers are more for jobs where they’d rather avoid the extra disruption and cost of replacing/repositioning the back box, or where they need to bring the socket forward after panelling, tiling, etc. so it finishes flush with the new wall surface. 🙂
I have to ask.. Is this the only item you make and sell? I buy perhaps 2 single spacers per year and 2 double, simply to get me out of trouble when all the new cables I've put in an existing back box (metal or plastic) do not fit in and for whatever reason it's too difficult to change it to a larger box, or its in a place where the customer doesn't mind how it looks. For me personally, it's not something I spend much time thinking about. It has to be white, rounded edges and i buy 4 per year.
